How Much Front Motor Mount Flex Is OK?
Old Jan 8, 2013 | 08:39 PM
2therock's Avatar
2therock
Default How Much Front Motor Mount Flex Is OK?
2002 Grand Caravan Sport 3.3
I have been chasing a vibration @ Idle in gear with brake on.
I had a friend hold the brake and bump the gas a little to observe the engine for movement.
When done in reverse its pretty solid.
When done in drive I can see the front mount under the radiator flex at least an inch.
OK? No-K?
Old Jan 8, 2013 | 10:48 PM
steak59's Avatar
steak59
well, try put a floor jack and block of wood under the oil pan, jack the motor up about half of a inch. Is the vibration gone? if it is, you probably have bad Motor Mount.
Old Jan 10, 2013 | 12:30 AM
mbrahmer's Avatar
mbrahmer
The motor mounts come in seperate pieces. You can get the inner part from Amazon for about $10. I'm ordering mine soon for the same kind of vibration ( all 4).
Old Jan 10, 2013 | 11:35 AM
in2pro's Avatar
in2pro
My wifes 2002 Caravan vibrates at a stop in gear... I have been told it is probably the mounts... please do post some pictures and how it went...
Old Jan 10, 2013 | 09:15 PM
2therock's Avatar
2therock
Hi guys, It gets a little worse with the AC on. The mounts are fine. If and when I nail it down I'll be back. Its on the back burner now.
Thanks
