2006 Dodge Caravan issue where at night the headlights work, but the tail lights wont
I have a 2006 Dodge Caravan. I have an issue where at night the headlights work, but the tail lights wont. They go on with the break, and backup lights work. The hazard lights even work. I am not sure what's wrong. I should also add that I do have a rear backup cam installed which works as it is supposed to when I backup. Can anyone give me any ideas?
The same bulbs worth the hazard and stop lights. Both of which are working. I was told that the BCM is shot, but I am not sure about that since everything else works. How can I tell for sure if it's the BCM, or what?
Cant figure out why the running tail lights would just stop working like that. Perhaps I will start with disconnecting the camera.
To eliminate the BCM as a cause, test the output from the BCM to the tail lights. The backup, hazard and brake lights run off of a different circuit from the BCM so the particular output from the BCM to your "running" lights may have failed which means a new BCM.
Just so we're on the same page, the front park/turn sigs lights are working correct? If yes that would eliminate the park lamp relay, the relay control ground from the FCM, and the fuses involved. Have you disconnected the camera yet? Do you have a trailer lights kit installed? Disconnect it. Are the license plate lights working? If yes, you're getting power out of the FCM to the left rear parking light circuit.
Try some monkey work before you grab a meter. Disconnect the negative battery cable for 5 minutes. This will reset the BCM, FCM and the PCI data bus. Disconnect the battery cable again then remove the FCM. It's that box bolted to the front of the IPM (fuse box). Inspect the connections for any corrosion or damage. Reinstall and remove it a few times to clean any unseen corrosion. Connect the battery cable and give the lights a try.
Would you like the wiring diagrams? Send me a private message with an email address included.
Trending Topics
I then went to Autozone with the relay I needed and the computer kept showing the wrong one. The associate went to the back and found the correct one. The relay cost me $15 which I thought was a lot for an item like that. Now I have to figure out who swiped my relay.
I am soo glad it was not a major repair I needed like the good folks over at the Pep Boys shop in ST Cloud FL would have led me to believe. They said that the "BCM was shot" I did not think I was missing a relay. I would think maybe a fuse or something.
Thank you for your help Cougar.
