2004 Dodge Grand Caravan sliding door locking issue
Old Feb 16, 2013 | 11:55 AM
drogers100's Avatar
drogers100
Default 2004 Dodge Grand Caravan sliding door locking issue
We have had the issue with rear sliders not locking and unlocking with the key remote and have just learned to live with it. I tried the fuse trick and disconnecting the battery multiple times but it never has worked.
New issue has come up with the drivers side slider where you lock the door and you can still open it using the outside handle. I engaged the child safety lock and tried opening from the inside and it worked as expected (I was unable to open the door).
At this point I could care less about the remote locking issue but if anyone has any idea what is causing the door to open from the outside with the lock engaged I would appreciate any advice.
Old Feb 16, 2013 | 05:36 PM
Tizzy1's Avatar
Tizzy1
So the front doors work ok? Is the lock **** on the door going down when you lock the sliding door? Do the power locks work with the power lock switch on the doors?
