08 Gnd Caravan Rear Hub
Old Mar 4, 2013 | 12:56 PM
Nick75's Avatar
Nick75
Default 08 Gnd Caravan Rear Hub
I've done the brakes so I have it to that point...what tools do I need to go on to replacing the rear wheel hub?
Old Mar 4, 2013 | 02:29 PM
Tizzy1's Avatar
Tizzy1
once you have the rotor off, 4 bolts on the back side of the bearing and pound it off. If you have a wheel speed sensor it may come with as well.
Old Mar 4, 2013 | 02:54 PM
Tizzy1's Avatar
Tizzy1
size of the bolts appears to be 16mm or 5/8 head.
Old Mar 4, 2013 | 09:07 PM
steak59's Avatar
steak59
And a BIG hammer.
I think the bolt size are 15MM. but not 100% sure.
why are you replacing wheel hub? just curious. I don't see them go bad too often. And the Front wheel bearing has a 90k miles extended warranty.
Old Mar 5, 2013 | 08:03 AM
Nick75's Avatar
Nick75
Tizzy thx for the help.
steak59 - the front were replaced by dealer recall at 80k miles, soon after the rear started making noise & have added 20k on top of that & the roaring noise is at the point where its almost gone.
is there a center/hub nut in rear?
Old Mar 5, 2013 | 11:09 AM
Tizzy1's Avatar
Tizzy1
no. I checked the bolt size on an '11 model so yours may be different, but the '11 was a 16mm bolt.
