brakes and brake pedal
Old Mar 25, 2013 | 06:10 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
Default brakes and brake pedal
on my 2010 I seem to find that on a light I waiting this will happen. I pressing down on the pedal when all sudden I can feel like the pedal is pushing back up on my foot. like if build up of pressure.
Old Mar 26, 2013 | 12:15 AM
kuyabribri's Avatar
kuyabribri
I'm not all that knowledgeable about that end of the brake system, but I would suspect a problem with the brake booster. It sounds like ambient air is leaking onto the vacuum side of the booster drum. It's remotely possible that you have an ABS problem, but an ABS problem would usually give you a CEL/MIL or the red BRAKE light would remain on after you release the parking brake.
Is the pressure buildup accompanied by any sound? And does the pedal feel normal the next time you stop?
Old Mar 26, 2013 | 07:38 AM
DodgeCaravan2010SXT
it sounds normal and feels normal. just it seems to me pushs up like a couple inchs at most when stopped for a while. no cel or lights on,
Old Mar 26, 2013 | 11:44 AM
kuyabribri's Avatar
kuyabribri
If that's the case then I'd lean towards the brake booster system. It could also be a vacuum problem elsewhere that's creating this symptom.
Old Mar 27, 2013 | 07:30 AM
DodgeCaravan2010SXT
van runs like normal just slight more fuel usage but that's probably more city and short trips lately while cold. guess I just keep a eye on it. rear brakes been acting up servicing them every 20,000km so not sure related aswell.
