Brake controller - 2013 Caravan Crew Plus
Old Jun 19, 2013 | 08:26 PM
LeonardoKogan's Avatar
LeonardoKogan
Default Succeed installation on a Dodge Caravan 2013 with factory tow ackage
I've successfully installed the break controller follow the jeep instructions.
the only difference is that you have to take the blue cable that is coiled up in the motor compartment and send back to the driver's compartment And the break wire is withe withe a green stripe (you have to tested to be sure).
To pass the cables i used a flat screw driver to punch the whole trough the rubber barrier (is hard you will here two pops).
I didn't used an utility knife because the space is too tight and I was afraid of cutting some wires.
After that I used a dry-cleaner hanger i passed it through the whole and then attached the cables to the end, tape them and pulled them inside.
the rest of the installation is like the Jeep except for the break cable (the white with the greens stripe one)
here some pictures:
https://www.dropbox.com/s/wsutoaz621...ue%20Cable.jpg
https://www.dropbox.com/s/zmk2mtcbps...r%20hanger.jpg
https://www.dropbox.com/s/kkls4mil8i...ape%20them.jpg
https://www.dropbox.com/s/havgj0mcro...led%20them.jpg
Old Jul 11, 2014 | 11:47 AM
swrving's Avatar
swrving
Thanks for the information in this thread (posts/pics from LeonardoKogan and links to etrailer videos). I was able to successfully install my Hopkins brake controller to my 2013 Dodge Grand Caravan R/T with tow package.
I also found the brake signal wire to be white with green stripe.
