Leak on carpet on passenger side
Old Apr 9, 2013 | 07:58 PM
wilburno's Avatar
wilburno
Default Leak on carpet on passenger side
The A/C is leaking on my Caravan. It is leaking down the floor panel from the drain port area on the inside. I changed the cabin air filter and washed out the drain port. It leaks worse since installing the cabin air filter than it did when I ran it without the filter. I looked at the drain port on the outside while the A/C was running, and it is open, and draining. Is there something else I can do to make it drain out the port and not leak inside?
Thanks,
Wilburn
Old Apr 10, 2013 | 08:35 PM
clinteastwood's Avatar
clinteastwood
Why would you change the cabin air filter if you have a leak still? Does it smell sweet? You probably need to have the heater core replaced. How much coolant do you current have in the radiator?
Old Apr 11, 2013 | 07:54 AM
wilburno's Avatar
wilburno
It is not the coolant. It is not a heater core problem. It has no smell. I changed the cabin filter because it was very dirty. The leak is definately (as I stated before) from the A/C drain. Since my first post, I used some heavy duty silicone, and caulked around the port exit on the inside of the firewall. As of now (one day later) it is not leaking.
Wilburn
Old Apr 11, 2013 | 08:22 AM
lionarus's Avatar
lionarus
Wilburn
Usless.
Try this...
find this plastic drain in hood space:
Check it for leaking - if leaking find any tube and put it upon this drain nipple like that:
Old Apr 11, 2013 | 08:25 AM
lionarus's Avatar
lionarus
Old Apr 12, 2013 | 07:48 AM
wilburno's Avatar
wilburno
Thanks, Lionarus,
I'll try it. Thanks for the photos.
Wilburn
