93 caravan shaking front end
Old Apr 10, 2013 | 06:06 PM
roughneckin28's Avatar
roughneckin28
Default 93 caravan shaking front end
Ok im sorry first of all if this has been answered in another thread. I have a 1993 dodge grand caravan that the front end shakes on at 50 mph. I have replaced both uv joints new tires and i even rotated them thinking that a tire might be the problem. The reason i replaced the uv joints was severe shaking in the front end. It is alot better now however the front end still shakes a little a 50 mph. Any thoughts on what i might can be. Any help would be appreciated.
Old Apr 10, 2013 | 07:06 PM
clinteastwood's Avatar
clinteastwood
Are all the wheels still balanced? None of them are missing a balance weight? Rotating the tires won't do much at all besides locating which tire is the problem, unless you meant balanced. Otherwise check ball joints, tie rods, etc.
Old Apr 17, 2013 | 01:06 AM
roughneckin28
Thank you i will check the tie rods and ball joints next. I will post my update after i do. Yes all the wheel weights are still there and the tires are balanced as well.
Old Apr 20, 2013 | 01:42 PM
smokesxt's Avatar
smokesxt
It's possible you got an axle that's out of balance as well. Exptalking
