2001 caravan help
Old Apr 15, 2013 | 09:38 PM
wildman72's Avatar
wildman72
Red face 2001 caravan help
I have a 2001 grand caravan 3.3,well this is what happened driving one day I stopped at a store shut the van off and it was hard to start and then it quit and had to get It towed ,so the fuel pressure was really low so I put a pump in it and now I have 60 psi and I put a new cam sensor in it and a crank sensor and ect sensor ,so here is the problem the van will start sometimes and it will kick and kick ,but if I unplug the ect it will fire right up like normal ,any help would be great
Old Apr 16, 2013 | 03:20 PM
Tizzy1's Avatar
Tizzy1
wrong ect or timing is off. When you unplug the ect, timing goes to a base setting so it timing was too advanced, unplugging ect would put it back. Why did you put all the sensors in?
Old Apr 16, 2013 | 04:29 PM
wildman72's Avatar
wildman72
I put the new cam sensor in because that was the code I got.The ect is reading right on the scanner so the pcm is getting the correct reading from it
Old Apr 17, 2013 | 10:21 AM
Tizzy1's Avatar
Tizzy1
Timing chain might be off then
Old Apr 18, 2013 | 07:29 PM
wildman72's Avatar
wildman72
ok I checked the timing chain and it is good and the marks all line up,do you think a cracked flywheel would do this,there are no noises in the motor but im trying anything at this point
Old Apr 19, 2013 | 10:54 AM
Tizzy1's Avatar
Tizzy1
You bet it could. That is probably a darn good road to go down.
Old Apr 19, 2013 | 02:41 PM
Cougar41's Avatar
Cougar41
Hmm. Did you just reveal a pretty slick troubleshooting aid when timing may be an issue? I'll remember the ECT next time. Sad thing is I knew about the ECT setting timing to a predetermined level but never put it all together. Thanks for your insight Tizzy1.
