engine code emission below threshhold bank 1
Old Apr 16, 2013 | 11:42 PM
wrighteous's Avatar
wrighteous
Default engine code emission below threshhold bank 1
We have a 2008 DGC 3.3ltr iv replaced the egr valve the O2 senso plugs and wires it still gets p402 below threshold bank 1 code any takers ideas I was thinking mabe egr solinoid .
Old Apr 16, 2013 | 11:51 PM
steak59's Avatar
steak59
first, clean the EGR tube to make sure it is not restricted.
second, pull the Battery Terminal off for 5 minute to get a hard reset.
third, maybe your New EGR valve is bad, did you get it from the dealer or Autozone?
Old Sep 28, 2019 | 11:27 AM
Watkins's Avatar
Watkins
make sure to use mopar 02 sensors. I replaced with bosch and still had the same problem. used mopar, problem solved.
Old Sep 30, 2019 | 12:39 PM
Chris Hoca's Avatar
Chris Hoca
Default Check fuel
I myself and have read that others have had o2 sensor readings from low fuel pressure. The regulator is part of the sending unit. You may need to add a schrader valve before the rail to test.
