edgarfunt
Old Apr 18, 2013 | 11:32 PM
edgarfunt's Avatar
edgarfunt
Default edgarfunt
I have a 1995 Dodge Caravan that shows no codes but the low fluid level and airbag lights are on.The cruise control doesn't work.The situation that I need help with is the engine will quit @40-45 mph, coasting it might start back up on it's own or I pull over and I start it. I put a cap & rotor on because they were bad and a new fuel filter.The fuses are all Ok. Help Me Please.
Old Apr 19, 2013 | 07:02 PM
master tech's Avatar
master tech
Site Moderator & Tech
I'm guesting you have a 3.0 engine with maybe a 3 speed transmission? The clockspring will cause the air bag light to come on, along with no speed control and horn. If you have a 3 speed transmission, replace the speed sensor.
