Caravan Side Door Motor Removal
I need to remove the motor which drives the passenger side door to diagnos the problem of binding. Can anyone help. 2005 Grand Caravan.
Thanks Les ermisle@att.net
The door panel just comes off, held on by push pin fasteners. When you get the panel off, you will see the motor, it is also held on by push pin fasteners but they are heavy duty. There is a cable that runs down to the gear drive. You can disconnect that and see if the binding goes away.
