94 Dodge Caravan shifting problems
Old Apr 30, 2013 | 02:21 AM
margel's Avatar
margel
Default 94 Dodge Caravan shifting problems
I have a 94 Dodge Caravan that shifts just fine until you have to stop; then it will not shift up, seems to be stuck in 2nd until you shut it down and restart it. Once you restart, it shifts just fine until you have to stop again. Any ideas on where to start with this issue?
Old May 1, 2013 | 01:05 AM
master tech's Avatar
master tech
Site Moderator & Tech
Did you know if you have a 3 speed or 4 speed transmission?
Old May 2, 2013 | 06:17 AM
margel's Avatar
margel
Default 3 or 4 speed transmission
I don't know if it is a 3 or 4 speed tranny, where would I look to find that information? I do know that it is a 3.8 engine.
Old May 30, 2013 | 11:52 AM
margel's Avatar
margel
Found that a can of Seafoam transmission tuneup cleaned up the transmission just fine. A filter change and new Dextron ATF-4 the transmission is shifting just fine for now! BTW, I believe it is a four speed transmission, 3.8 L engine.
Old May 31, 2013 | 10:35 PM
master tech
Thats correct. The 3.0 engine could either have a 3 speed 31TH transmission or the 4 speed 41TE transmission. The 3.3 and 3.8 only have the 41TE transmission, and the 3.8 can also be 41AE. Which is the All Wheel Drive transmission.
