A/C idle
Old May 13, 2013 | 10:16 PM
G SKI's Avatar
G SKI
Smile A/C idle
06 grand caravan, front and rear a/c. What controls the idle with a/c on? The rpm stays the same on or off. Does the computer keep rpm constant?
Old May 14, 2013 | 01:19 AM
Cougar41's Avatar
Cougar41
Yes. The PCM detects the A/C was commanded on and responds by commanding the Idle Air Control (IAC) valve open allowing a higher volume of air to bypass the throttle plate in the throttle body and maintain the specified idle RPM.
Old May 14, 2013 | 08:55 AM
G SKI's Avatar
G SKI
So would you see an rpm increase or does the rpm remain constant
Old May 14, 2013 | 10:35 AM
Tizzy1's Avatar
Tizzy1
remains constant. Why?
Old May 14, 2013 | 08:04 PM
G SKI's Avatar
G SKI
My wife uses the van for work, Town is only 15 miles long so alot of short trips in a day. Running the a/c constantly, most of the time the trips are not long enough too even cool down the van up front. So i am concerned that the battery is not getting enough of a charge. Its 107 degrees again today. It seems like an early summer ,but this is normal in the Arizona desert.
Old May 15, 2013 | 11:10 AM
Tizzy1's Avatar
Tizzy1
Running the a/c will have no affect on charging the battery. The 107 degrees might....lol
Old May 15, 2013 | 04:05 PM
Cougar41's Avatar
Cougar41
You might see a slight blurp in RPM when you turn it on but idle RPM should recover immediately.
Might consider a trickle charger or just check the static and charge voltage at the battery now and then.
Old May 15, 2013 | 09:27 PM
G SKI's Avatar
G SKI
Ok. Thanks for the quick reply, will do . Have a good day!
