how do i replace driver side mirror 96 dodge caravan
Old Sep 22, 2005 | 07:02 PM
macwanraj's Avatar
macwanraj
Default how do i replace driver side mirror 96 dodge caravan
how do i replace driver side (left) mirror on 96 dodge caravan.
Old Sep 24, 2005 | 12:32 AM
brandoncrone's Avatar
brandoncrone
Default RE: how do i replace driver side mirror 96 dodge caravan
Open the door and at the base of the mirror facing the drivers door jamb there is a philliips head screw there, take that off and slide the plastic piece forward. That will reveal two T30 torx head screws at the bottom of the mirror. Remove those, also facing the drivers door jamb above the removed phillips head screw you will see a hole in the mirror housing, there is another T30 torx in there. Remove that and the mirror can be removed. If they are power, you will find a red connector, use a small flat screwdriver and push it inbetween the locking tab and the connector and disconnect the connector. Installation is reverse of removal.
Old Sep 24, 2005 | 01:10 AM
macwanraj's Avatar
macwanraj
wow that is one superb answer with clear instructions.
thanx a lot boss.
