1996 3.0L Timing Belt Question
Old May 21, 2013 | 03:39 PM
nealkas's Avatar
nealkas
Default 1996 3.0L Timing Belt Question
Hello,
Replacing timing belt, and water pump on 1996 3.0L Mitsu/Dodge motor
Timing belt is already broken and the engine was cranked.
My question is:
If I match up the timing marks on both cams and the crank is the engine at TDC?
Or is it possible to have one of the cams or the crank 180 out?
Did a bunch of Forum-Fu and Google-fu, still can't be sure.
Thank you!
nealkas
Old May 21, 2013 | 03:53 PM
DanRaymond's Avatar
DanRaymond
my 1972 dodge pickup needs adjustments on timing? how can i adjust without timing gun?
