Break help 2001 Grand Caravan Sport
Old Jul 5, 2013 | 07:05 AM
  #31
moldmaker70's Avatar
moldmaker70
I can drive it but its not fun....stopping anyway. I'm at the garage waiting to talk to him. Will post what he says.
Old Jul 5, 2013 | 08:50 AM
  #32
moldmaker70
Had to go to work so needless to say he wasn't here yet. Will stop by thos afternoon and post update. Question.....if the brake pads are smoking (both left and right) couldn't that pump be causing that? I'm still wondering how if the ABS is disabled and no power is going to that pump how it could be making too much pressure like he said.
Old Jul 5, 2013 | 01:10 PM
  #33
issakar's Avatar
issakar
Has the power to the ABS "brain" been removed? IE, fuses pulled.
I suppose it's plausible the ABS pump could be creating pressure causing the brakes to hang up, which would of course cause heat. If you're seeing smoke, I would advise against driving it until this gets sorted out :-o
I'm interested to hear what the mechanic has to say.
Cheers
Old Jul 5, 2013 | 05:12 PM
  #34
moldmaker70
Ok I talked with him and he's convinced its the pump. Said he's come across this before. Said that none of the codes made any sense. Never really got a straight answer about pulling the fuses and trying it. I did call the local Dodge dealership and asked them about it. That guy told me that if the ABS system is disabled that it would not make too much pressure and cause the shaking. I'm going to take that side a part tomorrow and check everything over from the rotor to the slide pins. You wouldn't happen to know where I could get a schematic of all the parts and how they are assembled to make sure nothing is missing or put together improperly?
Old Jul 5, 2013 | 05:14 PM
  #35
issakar's Avatar
issakar
As far as the brake components go?
Old Jul 5, 2013 | 06:45 PM
  #36
moldmaker70
Yes, b/c I noticed when I bought the new caliper that there are a few small metal clips that look like the may go on the pads. When I changed the pads they didn't have them on them.
Old Jul 5, 2013 | 06:56 PM
  #37
issakar's Avatar
issakar
^^ like this?
Attached Thumbnails Break help 2001 Grand Caravan Sport-auto-part-brake-caliper-pad-clips.jpg
Old Jul 5, 2013 | 10:53 PM
  #38
moldmaker70
Yes very similar.....looks like those except cut in half.
Old Jul 5, 2013 | 11:02 PM
  #39
issakar's Avatar
issakar
word. The pic I linked about are anti rattle clips for the pads to keep them from squealing. Likely the same thing.
Old Jul 6, 2013 | 09:46 AM
  #40
moldmaker70
Not sure if that would cause the issue. I guess that I will take it to Dodge and let them check it....what's another $80 when you put it against $700.
