98 dodge caravan asd relay and starter
can the starter if bad cause the asd relay to click rapidly during the act of cranking the engine over i have a 98 caravan that when i try to crank the engine over it trys to turn over but the asd relay will start to just click causing a power no power situation to the starter and the fuel pump any help would be appreciated
ok after long hours yesturday searching wires down from 9 am till about 10 pm making sure i didnt have a broken shorted out wire i did end up replacing the cam sensor and recharging the battery the van is running now hope i can keep it that way i have been having this problem of the vehicle shutting off at any given moment and having to cool off before i could thing to restart it due to the asd relay rapidly clicking and when that would click the fuel pump would as well thank you for the info i hope i have finally nailed this down.
