Battery Light 02 Caravan
Old Jul 20, 2013 | 11:05 PM
kac060996's Avatar
kac060996
Default Battery Light 02 Caravan
Battery light is still on after replacing the alternater which was wore out after 11 years. Battery checks good but has a low charge. Checked fuses and relays. Pulled Alt and had a recheck done at Autozone which it passed. Checked all connections three times or more. Mmm, and there is serious static on the radio but not when you play a CD which started after the alt replacement. Any ideas? I think it is the alt but.....
Old Jul 22, 2013 | 04:08 PM
GearMan90's Avatar
GearMan90
I would have to say its a bad ground or a bad alternator. Alternators are mostly rebuilt, not brand new these days. You could of got a bad one. Double check the ground connections on the alternator, and depending on the warranty you got, try and get another one put in.
Good luck!
Old Jul 22, 2013 | 08:20 PM
kac060996's Avatar
kac060996
Took it back and got a new one instead of rebuilt. Talked to a few guys at work and they told me the same thing. They do not do a total rebuild. Works great now, thanks.
Old Jul 22, 2013 | 09:56 PM
2013 Grand_caravan SE_17s's Avatar
What about belt tension or resetting by disconnecting battery?
