Cooling Fan electrical connection
Old Aug 4, 2013 | 09:08 PM
silkysmooth95's Avatar
silkysmooth95
New Member
Default Cooling Fan electrical connection
1995 Caravan: I am needing to replace my fan assembly, but previously wired in a "universal" fan motor, and I tossed the wiring connector. I believe there are 4 wires that I used crimp connectors and taped it all up. Now, to purchase an oem fan assembly, I need to locate a connector for the fan motor. Can anyone tell me what this connector is called and where it may be purchased? I occasionally check salvage yards and Craigslist... frustrated because I can't find one. I would replace the motor only, but there is a spacer that has been stripped next to the lock nut that holds the fan on. Don't know where I can locate this part either, so I just am going to purchase the whole assembly. I have spare car parts from cars I owned in the nineties, and will probably never own another... I hardly ever throw parts away. Guess I figured I would never need this one again. WRONG. Thanks
Old Aug 5, 2013 | 12:03 AM
steak59's Avatar
steak59
Try calling the dealer. Tho, 1995 might be too old, Chrysler might no longer support these parts.
If no luck, try Aftermarket connector website such as this one
http://connectorexperts.com/
Make sure you take a photo of the fan's connector with a Quarter coin next to it, that way they know how it look, and how big the connector is so they can quote you the right one.
