07 Grand Caravan - Front Blower Motor Inoperable
Old Aug 13, 2013 | 10:16 PM
MarkWilliams64's Avatar
MarkWilliams64
Default 07 Grand Caravan - Front Blower Motor Inoperable
07 Grand Caravan SXT
The Front Blower Motor on our 07 SXT has pretty much stopped blowing all the time. If it does it is on a very low speed.
I physically looked at the Resitor, doesn't look burn out.
So I am assuming the motor might be bad.
Does anyone have instructions on how to test the motor?
And any instructions on how to remove and replace it would be appreciated.
I also heard if you change the motor you should change the resistor as well is that good advice?
Thanks
Mark
Old Aug 14, 2013 | 03:32 PM
Tizzy1's Avatar
Tizzy1
The resistor fails at the thermal fuse so you won't physically see it failed, have to check it with a meter. I would almost guarantee it is failed and that the motor caused the failing. I am sure there are motor removal threads on here all over but if you can't find one, let me know and I will send them to you.
