Windshield wipers pozessed
Old Aug 14, 2013 | 12:41 AM
Jim51's Avatar
Jim51
Default Windshield wipers pozessed
Here is an interesting one for you. 2003 Caravan with 218k km on the clock. In the middle of the night, Wife & I noticed a strange thump thump thump noise coming from out on the street where we park. Came outside this morning and windshield wipers are barely moving, battery is dead and I can't shut them off. That explains the strange thumping noise. I disconnected the battery and charged up the battery. Later, I hooked the battery up, started the van and all is OK ... everything works as it should. About 10pm, wife hollers "there's that thumping noise again." I go outside and the wipers are on. I unlock the doors, fire up the engine and can't turn the wipers off. Only thing I could do was pop the hood and unplug the connector. What would cause the wiper motor to run with the switch off and no key in the ignition without popping a fuse?
Old Aug 14, 2013 | 01:57 AM
steak59's Avatar
steak59
Probably the infamous Power Distribution Center failure. But kinda hard to say for sure.
What happen if you pull the fuse or the relay for the Wiper?
Old Aug 14, 2013 | 12:33 PM
Jim51's Avatar
Jim51
Cool
Could it be a relay inside the power distribution centre sticking? I was thinking it must be temperature related because the wipers start up in the evenings after the sun goes down.
Old Aug 15, 2013 | 10:38 PM
cpttuna's Avatar
cpttuna
check out my thread above yours. I had this happen twice. My wiprers are now wired straight.
