Help please
Old Aug 17, 2013 | 01:52 PM
Bigswann's Avatar
Bigswann
Default Help please
I have a 01 grand caravan with a 3.3 v6. The van spits sputters and backfires at low rpm. Once you give it some gas past 3000rpm runs great. I have changed spark plugs wires coil and IAC. Does anyone have any ideas what could be the problem? Any help would be appreciated.
Old Aug 17, 2013 | 03:53 PM
steak59's Avatar
steak59
Check Injector wiring harness that is routed behind the coil pack.
Old Aug 18, 2013 | 07:20 PM
Bigswann's Avatar
Bigswann
It also is showing a misfire on 5 and 6
Old Aug 19, 2013 | 09:46 AM
Cougar41's Avatar
Cougar41
All the more reason to check that harness. The exhaust melts the insulation shorting the wires together or to structure. A common problem especially on early 4th generation vans.
