02' Dodge Grand Caravan Sport 3.3L V6 Hard Start
Old Aug 21, 2013 | 01:43 PM
MichaelWinslow's Avatar
MichaelWinslow
Default 02' Dodge Grand Caravan Sport 3.3L V6 Hard Start
Turns over,but takes 3-4 trys to start up after start runs smooth.Recently had to replace fuel pump cleaned the tank out replaced pump and filter,also threw code for Throttle position sensor relaced,then Idle air control valve was humming and vibrating so i replaced it.Cleaned the throttle body out.Replaced spark plugs and wires when I the changed oil.Currently not giving any codes.
Old Aug 21, 2013 | 02:55 PM
Cougar41's Avatar
Cougar41
Hard start all day or just in the morning after sitting all night? Cycle the key from off to on a couple times to prime the pressure. If it starts easier you have a leak in the fuel system bleeding pressure down. These leaks are usually at the pressure regulator, the top of the pump or a fuel injector.
