2010 Caravan 4.0 Electrical Issues- Dash
Old Aug 31, 2013 | 09:02 PM
Barker's Avatar
Barker
Question 2010 Caravan 4.0 Electrical Issues- Dash
Randomly now becoming more often. Started on extremely hot days, stop and go traffic or a long trip followed by stop and go. All dash lights tach and speedo go haywire , all dash lights flashing on and off,eventually staying on until the ignition is switched off and back on. At that point the service engine still remains on until a further on off or two of the ignition after a couple of short trips, sometimes may take a day or so after the episode.
Up until to-day the van performance has not been affected. However to-days episode happened on a short ride cooler weather, Switched the van off to cancel the light show, to my surprise nothing happened would not restart. After sitting in traffic for 15 minutes it did start lights out with exception to the service engine.
1st time I approached the dealer, no satisfactory diagnosis,
Appreciate any thoughts or ideas on this ?
Thanks
Paul
Old Sep 2, 2013 | 02:55 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
They're not going to give you a diagnosis until they can pin it down, being that it's intermittent. As for me, I would have to see a scan report to point you in a direction. The BUS circuits, especially the high speed interior, can show multiple symptoms if just one output of one module fouls up. If it's inhibiting your starting, then I would look to a starting point such as the Gateway (TIPM) or something that intersects the C-BUS and the IHS BUS like the Cluster or the Wireless Control Module.
Complexity is the enemy of reliability. The whole world is drowning in it these days.
Old Sep 2, 2013 | 08:30 AM
Barker's Avatar
Barker
Thanks for your reply, Van is scheduled to the dealer tomorrow I will relay your thoughts.
Old Sep 2, 2013 | 12:12 PM
TNtech's Avatar
TNtech
With the integration or more and more computers, EVERYTHING is a request signal and gets handled by a module to control the output. Sometimes a module will signal another module to control an output. The stated purpose for all this was less wiring, safety, bla bla, etc.
That's all well and good, but with all the little skinny wires, tiny terminals and the amount of tasks going back and forth over the BUS circuits, the percentage of intermittent electrical issues have grown substantially.
Some days most of the repair orders I get start off with....
"Customer States, At Times . . . . . . . ."
Old Sep 4, 2013 | 07:20 PM
Barker's Avatar
Barker
Back from the dealer, changed the WIN Module, fine so far. Time will tell........
In addition they replaced the rear rotors and pads (4th set of pads / fifth set of rotors) 96000 kilometers.
Old Mar 8, 2014 | 07:46 PM
emr4698's Avatar
emr4698
2010 Dodge Grand Caravan===Just to put my two cents in....I have had this issue for 15 months now. My dash board lights with begin going crazy, radio goes off, clock goes off, dinger starts dinging, speedometor, etc wildly goes up and down, and finally the van just dies, especially if I have to slow down. It used to start up again, but now I have to sit and block traffic until I hear a slight sound behind the CD player, that sounds like a computer shutting down. This takes about 5-7 minutes. The van will start then. However, I have been sitting in traffic, with NO warning lights/flashers, or ability to roll windows up or down. The vehicle has been to the dealer numerous times, a TIPM module was changed. Still, no better. I am scared to drive my car for fear that someone will crash into my rear. Not to mention that my job involves constant travel. So I have had to take days off, rent a replacement vehicle, etc, etc. I am due to take the van back in to Dodge AGAIN, Monday so they can drive it and see if it happens. Any suggestions????
Old Mar 9, 2014 | 01:25 AM
Cougar41's Avatar
Cougar41
If this applies you may want to have this done if not done already:
Report Receipt Date: MAR 01, 2011
NHTSA Campaign Number: 11V139000
Component(s): ELECTRICAL SYSTEM
All Products Associated with this Recall expand
Details close
13 Associated Documents expand
Manufacturer: CHRYSLER GROUP LLC
SUMMARY:
CHRYSLER IS RECALLING CERTAIN MODEL YEAR 2010 DODGE JOURNEY, GRAND CARAVAN, AND CHRYSLER TOWN & COUNTRY VEHICLES MANUFACTURER FROM AUGUST 3, 2009, THROUGH JUNE 17, 2010. SOME VEHICLES MAY EXPERIENCE INADVERTENT IGNITION KEY DISPLACEMENT FROM THE RUN TO ACCESSORY POSITION WHILE DRIVING CAUSING THE ENGINE TO SHUT OFF.
CONSEQUENCE:
ENGINE SHUT OFF WHILE DRIVING COULD INCREASE THE RISK OF A CRASH.
REMEDY:
DEALERS WILL REPLACE THE WIN MODULES FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING JULY 2011. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
NOTES:
CHRYSLER SAFETY RECALL NO. L02 & L25. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
