2005 grand caravan flashing lights
Old Sep 30, 2005 | 05:27 PM
mountain's Avatar
mountain
Default 2005 grand caravan flashing lights
2005 grand caravan, how to stop flashing lights every time open side doors, appreceiate your help, thank u very much!!!... mountain
Old Oct 1, 2005 | 01:22 AM
MGDMike's Avatar
MGDMike
Default RE: 2005 grand caravan flashing lights
I'd say check the owners manual or run it up to the shop...but in all out honesty I think you have a poltergeist with you.
j/k...good luck w/that and welcome to DF!
Old Oct 1, 2005 | 02:36 AM
mountain's Avatar
mountain
Thanks for the reply on the 2005 grand caravan flashing lights...I believe the owners man. states that when either side door opens the hazard flashers go off for 10 seconds or so to warn people that someone might be exiting from the vehicle but in my case I don't need this feature. Wondering how I could disconnect, any help would be appreciated.
Thank you for your time, mountain
Old Oct 1, 2005 | 03:21 AM
ramfan5.9's Avatar
ramfan5.9
welcome to DF, im movign this to the caravan section, it'll get mroe hits there and hopefully get u an anwser
Old Oct 1, 2005 | 04:25 PM
ViperGTS's Avatar
ViperGTS
If yout take it to a Dodge dealership they can probably disconnect it for you.
-Matt-
Old Oct 2, 2005 | 01:49 AM
dm3's Avatar
dm3
ORIGINAL: mountain
Instructions are given at least in my 2006 Grand Caravan manual, page 30. It says the procedure is...
1. Place the key in the ignition switch
2. Cycle the ignition switch on/off four times ending in the off position (do not start the engine).
3. Within 10 seconds of the final cycle, press the hazard switch
4. A single chime will sound to signify that you have successfully completed the programming.
You can turn the feature back on by repeating the above procedure.
