A/C Problem
Old Sep 11, 2013 | 12:15 PM
Bomber19's Avatar
Bomber19
Default A/C Problem
I have a 01 Town & Country that the A/c clutch won't engage, I can get it to work by removing the relay and jumping the terminals, blows great cold air, normally I would look to the low pressure switch but I can't seem to locate it. It has enough freon cause I just charged it. It has the auto climate control, just wondering if that could be the problem...any suggestions? Thanks!
Old Sep 12, 2013 | 11:18 AM
Tizzy1's Avatar
Tizzy1
There is no low pressure switch in the system. There is a high pressure transducer that reads system pressure and the evaporator temp probe that is used for clutch cycling. Both are sensors and cannot be jumped and would require a scan tool to read them.
Old Sep 13, 2013 | 09:36 AM
Bomber19's Avatar
Bomber19
Thanks Tizzy1 for the info, I have the relay toggled to run the air right now and it works good, I'm going to try and find a used control module. I think that's the problem
