03 Grand Caravan AC woks when cold but not when the engine warms up
i need some direction. I check to make sure the cooling fans are working and they are. Whem you first get in it in the morning the ac works find but if you drive it far enough to heat it up then shut it down. When you get back in it the ac want work. If the van sits most of the day it will blow cold. I have checked feon level with gauge from Auto part store and it is in the green. Please help.
