93 3.3 hesitates -- tends to want to stall
Old Oct 7, 2013 | 04:50 PM
93-AZ-DODGE's Avatar
93-AZ-DODGE
Default 93 3.3 hesitates -- tends to want to stall
93 caravan -- Runs great until it starts to hesitate -- chokes up -- it will repeat this several times -- as if it was not getting air?? gas?? slow down from 55 to 40 and it improves starts to run better.. back to 55 it gets worse --fuel pressure looks good ( with engine running ok) cleaned throttle body and idle air control no change...
it will run just fine for most of the day then suddenly acts up -- then runs ok for rest of day ??? any suggestions ?? thanks!!
Old Oct 8, 2013 | 11:02 PM
master tech's Avatar
master tech
Site Moderator & Tech
Check the AIS motor, it may need to be cleaned or replaced. Also check the EGR tube, the tubes will plug up over time and cause some idle problems.
