2011 Dodge Grand Carvan vs Coolant Temp?
Old Oct 16, 2013 | 03:31 PM
vpnavy's Avatar
vpnavy
Default 2011 Dodge Grand Carvan vs Coolant Temp?
My gauge always runs a little below and a little above half. I was monitoring the actual temperature and it bounces between 202 + or - up to 220 or so before it starts dropping back to normal. Is that normal? The high readings are when I am standing still (outside temperature was in the 60's).
Thanks!
Old Oct 16, 2013 | 10:23 PM
master tech's Avatar
master tech
Site Moderator & Tech
Yes it is normal. That's because the fans kick on at 220 to 228 degrees and then come down to 192 and the fans will kick off.
Old Oct 17, 2013 | 05:04 AM
vpnavy's Avatar
vpnavy
Thanks a bunch for your response. The only problem is now I can worry about something else!
Again - thanks for the explanation.
