2008 Grand Caravan rear spoiler
Old Oct 22, 2013 | 09:08 PM
dhayes1's Avatar
dhayes1
Default 2008 Grand Caravan rear spoiler
How do you remove the spoiler from the tailgate on the grand caravan?
Old Oct 23, 2013 | 04:33 AM
papillon2375's Avatar
papillon2375
For the dismantling of the spoiler, you need to remove the plastic lining of the tailgate, it consists of two parts - upper and lower. You need to remove the top. Spoiler mounted on the 4 nuts, which are located in the holes of the top of the door. After you remove the 4 nuts, spoiler need to pull up to rip it with clips. Them there 5. Be careful design is poor, to tear fastening clips. Good luck!
Old Oct 23, 2013 | 08:18 AM
dhayes1's Avatar
dhayes1
Thanks for the info. Is it difficult to remove the plastic lining? Or does it just snap out?
Old Oct 23, 2013 | 11:05 AM
Tizzy1's Avatar
Tizzy1
just snaps out
Old Oct 24, 2013 | 08:18 AM
dhayes1's Avatar
dhayes1
Thanks for the info. I have to remove it to get at the 3rd brake light which has a loose connection. It goes off but when I hit the spoiler it comes on.
Doug
Old Oct 24, 2013 | 02:09 PM
papillon2375
When you remove the spoiler, you understand everything. Most likely you have a faulty connection additional stop signal. Stop light solid element, the need to replace it completely. Nothing complicated, the first time it is difficult, in the future will be easy!
Old Oct 25, 2013 | 07:55 AM
dhayes1's Avatar
dhayes1
Thank ou very much for the information
