Brake line Problem
Old Oct 25, 2013 | 10:57 AM
avery53's Avatar
avery53
Default Brake line Problem
I need to change the flex brake line on a 99 Caravan. The one from the MC to the ABS module.
The line that goes to the front of the module is impossible to get to with a wrench. Even tried a crows foot wrench, no luck.
Has anyone ever succesfully changed this line yourself?
Any help would be greatfully appreciated.
I am including a picture that was taken by IndyMike showing the line set up on the module, it is the line farthest away in the picture.
Mike, if you don't want your picture used, I will remove it and take one of my own.
Thanks avery
Old Oct 25, 2013 | 07:05 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
if you replacing that line I loosen all the ones and then cut off the line to remove the module then you probably can have better access. spray it with some penetrant. or maybe u could try heat it up a bit then let it cool. then wrench it.
Old Oct 26, 2013 | 11:26 AM
Town's Avatar
Town
Cut the line just behind the nut and use a 6 point tight fitting socket to loosen the nut. A little penetrating fluid helps. A wrench, even a line wrench, has too much flex.
Applying heat may possibly damage the seals in the HCU.
Good luck.
