Heavy duty 2 pistons front brakes on cheapest CVP + winter rims info
Old Nov 1, 2013 | 06:22 PM
Irodd's Avatar
Irodd
Default Heavy duty 2 pistons front brakes on cheapest CVP + winter rims info
I got 2014 Caravan Canadian Value Package and surprisingly it has Heavy duty 2 pistons front brakes inside 17" steel rims.
It is Impressive brake performance but no possibility for "minus size" winter tires/rims.
Also regular(for SE/SXT/CVP) 17" steel rims do not fit properly - the brake caliper touches the rim. You have to order rims for Crew/R/T models.
I believe same situation is with AVP.
Most Canadian tires/rims retailers(CanTire, Costco) use rims from Macpek.
The correct part number for Caravans with HD Brakes is 44753 only!!!
Old Nov 2, 2013 | 01:16 AM
master tech's Avatar
master tech
Site Moderator & Tech
That is great pictures. I haven't seen the brakes on the 2014 yet, But I think that will help with the brake wear problem that dodge has had.
