2008 DGCV overhead dvd system
Old Nov 2, 2013 | 08:13 AM
ebxgsxr's Avatar
ebxgsxr
Default 2008 DGCV overhead dvd system
tried searching, but couldn't find anything. the VES overhead console in my 2008 DGCV has developed a squeaking when driving down the road. i wanted to try to put some sort of foam spacer under it (between the headliner & the console). but i couldn't find anything on how to remove it on here. just wondering if anyone has ever done it before. i'm also going to check you tube to see if someone put anything on there.
any help is appreciated.
Old Nov 5, 2013 | 09:00 PM
georgef's Avatar
georgef
Here's a link to the Overhead Console Installation Guide K6860331.PDF from the Mopar accessories store. You can use it as a guide to remove the console.
George
Old Nov 5, 2013 | 11:16 PM
master tech's Avatar
master tech
Site Moderator & Tech
Also send a pm to tizzy1. He has pretty good knowledge on things like this.
Old Nov 6, 2013 | 08:01 AM
ebxgsxr's Avatar
ebxgsxr
thanks for the info guys. looks easy enough. i wonder if the mounting bolts may have just started getting loose. guess i'll try tightening everything 1st. thanks very much for the help.
