[3rd Gen : 96-00]: Problems with accessories not working after timing belt change.
Old Dec 1, 2013 | 03:38 PM
trdriver71's Avatar
trdriver71
Default Problems with accessories not working after timing belt change.
I just replaced the timing belt in my caravan with a 3.0 it is a 2000 grand caravan. I have no headlight and no gauges and wipers and also no interior lights as well as power locks. I was thinking it might be the ignition switch anyone else with some ideas?
Old Dec 1, 2013 | 08:17 PM
Cougar41's Avatar
Cougar41
All functions of the Body Control Module (BCM). Try either pulling the IOD fuse or disconnecting the negative battery cable for 2-3 minutes to reset it.
High beams working? They are independent of the BCM.
Old Sep 14, 2014 | 08:41 PM
yoyo7's Avatar
yoyo7
I have the same problem but not power door locks. I pulled the instrument cluster and saw one crack /solder on pin where main connector attached. Took care of that and no change.
I am leaning to replacing BCM. I don't know what dealers do to find codes to check for that. I have a code checker and no codes showed up.
Did U get yours fixed since late last year??
