[4th Gen : 01-07]: rear supension recommendations
Old Dec 4, 2013 | 02:00 AM
write2arnaud's Avatar
write2arnaud
Default rear supension recommendations
Hi, i have a 2002 Grand Caravan ES 3.8 I need to replace the rear shocks but I can't afford stock ones. $600 each, that won't happened. I see the Monroe shock, any one use these. I have a trailer that I pull and need the self leveling style shock. Thank you MONROE 58620 Rear Shock Absorber-Monroe Sensa-Trac Load Adjusting Shock Absorber.
Old Dec 4, 2013 | 11:15 AM
Tizzy1's Avatar
Tizzy1
I have a pair of lightly used factory load level shocks if you are interested. I was going to put them on my '03 but never got around to it. I think they had 30K on them
Old Dec 4, 2013 | 12:25 PM
steak59's Avatar
steak59
Personally, I wouldn't recommend using Monroe unless you are very tight on Budget. And those you proposed seem to be just Heavy Duty shocks instead of true self leveling shocks.
KYB or SACHS one is $250ish each, look around. I believe the Factory Mopar one are made by SACHS.
Old Dec 4, 2013 | 10:13 PM
write2arnaud
thx guys. I found this one too
Mouse over image to zoom http://www.ebay.com/itm/MONROE-40202...5de383&vxp=mtr
Old Dec 5, 2013 | 07:42 PM
Montreal300's Avatar
Montreal300
KYB Part # SR2005 SR Series; Self Leveling / Self Contained (Nivomat design)
Rear; AWD; w/ Nivomat Rear Suspension
These are 230 each from RockAuto
Old Dec 5, 2013 | 08:59 PM
mfahey's Avatar
mfahey
I replaced the Nivomat units with standard heavy duty shocks and can't tell the difference. I towed our sailboat and trailer(maybe 1,200 pounds total) a little over 1,000 miles and it did fine with the replacement shocks.
Old Dec 6, 2013 | 12:14 AM
write2arnaud
That's good news, thanks for letting me know.
