[5th Gen : 08+]: 2008 Town and Country 4.0L Rough idle
Old Dec 7, 2013 | 10:19 PM
Husamkhadra's Avatar
Husamkhadra
Default 2008 Town and Country 4.0L Rough idle
Hi,
I have a 2008 town and country limited 4.0L and I am suffering from
- Rough idle, its not horrible but you can feel it in the steering wheel.
- Hard shift 2-3 and sometimes 3-4, it has 61TE.
I appreciate your input
Old Dec 7, 2013 | 10:22 PM
Husamkhadra
Default What I did to the minivan and what is the current mileage
Current mileage 103K and did the following at the dealership with mopar parts
- Front and rear engine mounts.
- Transmission oil change and filter not a flush.
- Spark plugs, water pump, timing belt, accessory belt, EGR valve
- Radiator flush.
I will post more as soon I get my invoices
Old Dec 7, 2013 | 10:26 PM
Husamkhadra
Default More maintenance
- PCV valve.
- Front struts, one strut mount bearing and rear shocks.
- New after market battery
Old Dec 7, 2013 | 10:58 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I got your PM...
The 4.0L had the same problems with valves that the engine it was based off of did...the 3.5L. Need to do a compression test and also the timing of the timing belt needs to be rechecked. The data (cam/crank difference in degrees) can be read with a scan tool to see it. But, the camshaft that's not read by the cam sensor can also still be out and the data won't reveal it, but usually the adaptives for each bank will show enough evidence to take the timing cover off and look.
About the trans, I'm not a transmission guy. I purposely avoid tthem. I stay busy enough doing electrical and drivability. There could be a software update available though.
MasterTech is a trans guy though (:
Old Dec 7, 2013 | 11:30 PM
Husamkhadra
Originally Posted by TNtech
I got your PM...
Thanks, I will start my research about this issue.
Old Dec 7, 2013 | 11:37 PM
Husamkhadra
Default symptoms of valve problems
Forgot to ask, is there any other signs of the valve problem?
