[4th Gen : 01-07]: Brake fluid leak
Old Dec 10, 2013 | 12:51 PM
Jetman50's Avatar
Jetman50
Default Brake fluid leak
My wifes' 2002 Grand Caravan Sport developed a major brake fluid leak. I can't tell where it is coming from. I am hoping that my description of the problem may help someone here help me to determine the cause.
The left front stabilizer mount is soaked with fluid but I can't see further up to pinpoint the cause. I cannot see the leak looking down into the engine bay. There is some brake fluid on the left front tie rod bellows as well. The lower control arm mount at the rear is soaked as well. I have attached a picture although I don't think it will help much.
Brake fluid seems to be flowing down/following the sub frame, again I cannot see where it is originating.
If you need more info, please let me know and I'll answer as best as I can. Thank you in advance.
Attached Thumbnails Brake fluid leak-2013-12-10-12.41.37.jpg   Brake fluid leak-2013-12-10-12.41.17.jpg   Brake fluid leak-2013-12-10-12.40.44.jpg
Old Dec 10, 2013 | 10:07 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would look at the lines at the master cylinder and the bottom of the booster.
