[4th Gen : 01-07]: Problems filling fuel tank
I know several have had this problem with various vehicles. I have a Dodge Caravan 2006. I have had problems recently with the nozzle on the gas pump shutting off every few seconds as I try to fill gas. I have read the technical bulletin earlier. Although it does not cover my vehicle, I may try some of the suggestions there. But did anyone else have this problem, and how did you solve it? I need your advice as I try to solve the problem. Thanks.
Try this TSB. It should apply.
SUBJECT:
Hard To Fill With Fuel Or Fuel Nozzle Shuts Off Repeatedly
MODELS:
2004 -2008 (CS) Pacifica
2009 (DS) Ram Truck (1500)
2007 - 2009 (DH) Ram Truck (1500/2500 Pick Up)
2004 - 2009 (DR) Ram Truck (1500 / 2500 Pick Up)
2005 - 2009 (HB) Durango
2007 - 2009 (HG) Aspen
2005 - 2009 (ND) Dakota
2009 (JC) Journey
2007 - 2009 (JK) Wrangler
2007 - 2009 (J1) Sebring (China CKD)
2007 - 2009 (JS) Sebring/Sebring Convertible/Avenger
2006 - 2009 (K1) Cherokee (CKD)
2007 - 2009 (KA) Nitro
2008 - 2009 (KK) Liberty
2008 - 2009 (KK) Cherokee (International Markets)
2005 - 2007 (KJ) Liberty
2005 - 2007 (KJ) Cherokee (International Markets)
2005 - 2009 (LE) 300C/300C Touring (International Markets)
2005 - 2009 (LX) 300/Magnum/Charger
2007 (L2) 300 (China)
2008 - 2009 (LC) Challenger
2004 - 2009 (PT) Chrysler PT Cruiser
NUMBER: 14-001-09 REV. A
GROUP: Fuel
DATE: September 1, 2009
2007 (R2) Caravan/Voyager (CKD)
2005 - 2007 (RG) Chrysler Voyager (International Markets)
2003 - 2007 (RS) Town & Country/Caravan/Voyager
2008 - 2009 (RT) Town & Country/Grand Caravan
2008 - 2009 (RT) Town & Country/Grand Voyager (International
Markets)
2005 - 2006 (TJ) Wrangler
2005 - 2009 (WH) Grand Cherokee (International Markets)
2005 - 2009 (WK) Grand Cherokee
2006 - 2009 (XH) Commander (International Markets)
2006 - 2009 (XK) Commander
NOTE: This bulletin applies to all vehicles equipped with a gasoline engine.
DISCUSSION:
Customer may report that the vehicle is hard to fill with fuel or that the fuel pump nozzle
shuts off repeatedly while trying to fill vehicle.
This customer complaint can occur due to a number of different causes. The fuel tank is
the least likely cause of this condition. The following Diagnostic procedure can be used to
diagnose the issues.
DIAGNOSIS:
1. Is the vehicle a LX/LE/LC/L2?
a. Yes >> proceed to Step #2
b. No >> proceed to Step #4
2. Idle the vehicle 60 to 90 seconds upon stopping.
3. Does tank refill properly?
a. No >> proceed to Step #4
b. Yes >> Inform the customer to idle the vehicle for 60 to 90 seconds upon stopping if
vehicle was driven aggressively. This is due to the fact that on the LX/LE/LC/L2 the
fuel tank is a unique saddle tank design and needs 30 to 60 seconds while the
engine is running to level the fuel in both half's of the fuel tank. Allowing the vehicle
to idle for this amount of time will let the fuel pump transfer fuel to the left side tank,
opening the control valve and allowing normal fuel filling.
4. Disconnect the vapor recirculation tube at the fuel tank.
5. Attempt to refill fuel tank.
6. Does tank refill properly?
a. Yes >> Proceed to Step #7
b. No>> Proceed to Step #11.
7. Reconnect the vapor recirculation tube at the fuel tank.
8. Disconnect the other end of the vapor recirculation tube at the fuel filler tube.
9. Attempt to refill fuel tank.
10. Does tank refill properly?
a. Yes >> Replace fuel filler tube.
b. No >> Replace the vapor recirculation tube.
11. Disconnect the control valve to EVAP canister tube at the fuel tank.
14-001-09 REV. A -2-
12. Reconnect the vapor recirculation tube at the fuel tank.
13. Does tank refill properly?
a. No >> Replace Fuel Tank.
b. Yes >> Proceed to Step #14.
14. Reconnect the control valve to EVAP canister tube at the fuel tank.
15. Disconnect the control valve to EVAP canister tube at the EVAP canister.
16. Attempt to refill fuel tank.
17. Does tank refill properly?
a. Yes >> Blockage is in the EVAP Canister, or ESIM, or Clean air hose (ESIM vent
hose), or filter. Diagnose appropriately.
b. No >> Replace the control valve to EVAP canister tube.
POLICY:
Information Only
SUBJECT:
MODELS:
2009 (JC) Journey
GROUP: Fuel
Markets)
DISCUSSION:
DIAGNOSIS:
POLICY:
Information Only
I carried out these checks on my fuel tank problem, and it seems to be the tank! However, I am reluctant to believe this, and am reluctant to change the tank in case it does not solve the problem. I need to hear from anyone else who has experience with the same problem. And anything else I might try first. And where would I get an aftermarket tank if I decide to change it out? I have looked around on the net but few seem to carry them. What a pain of a problem! Thank you.
I had this problem with my 2006 ram. Once we had the problem checked out and had the tank replaced the problem was solved. It was a roll over value made inside the tank which means of course it can't be replaced or repaired, the tank has to be replaced
