[4th Gen : 01-07]: 2001 Dodge Grand Caravan trying to find overflow hose from Radiator to coolant tank
Old Dec 15, 2013 | 11:48 AM
riverjamie's Avatar
riverjamie
Default 2001 Dodge Grand Caravan trying to find overflow hose from Radiator to coolant tank
Just found out that the overflow hose is no longer available from the radiator to the coolant tank, from Dodge. Does anyone know where to find? Mine has some wear spots from rubbing. It's not leaking yet. Taped up, but would like to replace. I was thinking about talking to some radiator shop?
I think it might be 3/8 inch ID?
Thanks
Old Dec 15, 2013 | 12:28 PM
riverjamie's Avatar
riverjamie
Default Just found at Oreillys or Autozone
Prestone RT0308 3/8 ID. Only 2 ft, but can use barbed fitting to extend to 4ft. Should work. Autozone $2, Oreillys $4 but Oreillys with match prices on same items.
Old Dec 22, 2013 | 11:21 AM
riverjamie's Avatar
riverjamie
Default Update on parts
Installed Bosch 97218 water pump from Amazon, two came in defective, one had the impeller cocked, the other one pump housing bent from shipping. Finally the third one okay. Here's a tip, lightly glue in the gasket to hold it in place. Torque bolts to 105 inlbs. Also install Zerex G05 antifreeze for my car. Found radiator overflow hose from Prestone at Autozone, not available from dealer anymore. Need qty 2 $1.99, also need brass or plastic barbed fitting to joint the two hoses. Installed new radiator. Last installed new Radiator fans from Amazon TYC 600390 and 610390. New lower hose and Stant thermostat 14789 and Felpro thermostat gasket 35651.
Old Dec 22, 2013 | 07:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
Here is the mopar number, But it maybe a roll of either 5/16 or 3/8 hose. 04266423
Old Dec 22, 2013 | 07:55 PM
georgef's Avatar
georgef
It is a roll, 50 feet, cost is $161.00 MSRP.
George
Old Dec 23, 2013 | 12:22 PM
riverjamie's Avatar
riverjamie
Thanks George, just didn't need that much. The hose is 3 1/2 ft long.
