[4th Gen : 01-07]: P2302 Cope
Old Dec 18, 2013 | 03:55 PM
rod.west.sa's Avatar
rod.west.sa
Default P2302 Code and surge at 3000 RPM
I had a P 2308, P300 and P406 codes I have replaced the Plugs, Wires Coil (was Cracked) EGR valve and The PCM. now I have a P2302 code I have looked for any broken wires Trace the wire back to the PCM all looks good. Any suggestions I am at my wits end.
Old Dec 18, 2013 | 04:21 PM
rod.west.sa
one other thing the engine runs rough and surges at 3000 RPM some one please help.
Old Dec 18, 2013 | 04:42 PM
Cougar41's Avatar
Cougar41
First suggestion is please tell us the model year. Have you checked the wires for continuity using a meter? You could also check the driver pulse out of the PCM using a test light, new PCM or not.
