[3rd Gen : 96-00]: 1999Radio removal
Old Dec 26, 2013 | 01:42 AM
stephensonkeric's Avatar
stephensonkeric
Default 1999Radio removal
First remove the 2 upper bezel retainer screws at the top of the radio. Then remove the dash mounted cup holder assembly by reaching in the central compartment and find the release lever, push down, and pull out. Next, remove the small cover plate below the heater/AC controls (might stick a little depending on the last time it was remove). Next, remove the lower bezel screws.
Remember to remove the hot/com & fan "buttons". It works best by using a small vise-grip tool using just enough pressure to grip them without cracking them.
Then, disconnect the heater/AC wiring connectors to fully release the bezel.
Now, you can unbolt the right and left 3/8 inch bolts holding the radio in place. You can now pull the radio out and disconnect the plugs.
Installation is the reverse.
Old Dec 27, 2013 | 11:09 PM
master tech's Avatar
master tech
Site Moderator & Tech
RADIO/TAPE/CD PLAYER
REMOVAL
1.Remove HVAC switch bezel.
2.Remove screws holding radio to instrument panel Radio
3.Pull radio rearward to gain access to back of radio Radio Connectors
4.Remove bolt holding ground strap to back of radio.
5.Disconnect antenna cable from back of radio.
6.Disconnect the wire connectors from back of radio.
7.Remove radio from vehicle.
INSTALLATION
For installation, reverse the above procedure.
