[4th Gen : 01-07]: low oil senser
Old Dec 26, 2013 | 06:33 PM
ronman427's Avatar
ronman427
Default low oil senser
need help locating low oil switch any one have pictures for 05 g.c. 3.3 v6. Light keeps comming on at start. Shut it off light goes out oil is at correct level.
Old Dec 27, 2013 | 11:00 PM
master tech's Avatar
master tech
Site Moderator & Tech
The oil pressure switch is near the oil filter. Try replacing the switch, that would be the cheapest way.
Old Dec 29, 2013 | 10:50 AM
ronman427's Avatar
ronman427
Thanks will try it
Old Jan 1, 2014 | 11:48 AM
bdwillie's Avatar
bdwillie
Our 2005 3.3 l. Everytime the outside temp got below 35 degrees on fitst crank would get a constant oil light. It would go out as soon as you shut off engine and restarted. Happened everytime temp was below 35 degrees. Letting it continue to run woild not extinguish the lamp. Kust a restart. Replacement of the sending unit fixed it. No problems since.
