[5th Gen : 08+]: Over fill of Engine Oil 2013 GC SXT
Old Dec 29, 2013 | 12:04 PM
fielldboss's Avatar
fielldboss
Question Over fill of Engine Oil 2013 GC SXT
OK..so I purchased a 2013 GC SXT with 32000, didn't trust used car dealer on engine oil change so I changed to Mobil 1 5w 20 Synthetic.
Pour in 6 qts as specified...Dip stick now shows ABOVE safe line.
Is there an easy way to sphion off 16 ozs (I'm guessing) from the filler tube, with out have to pull the ramps on and draining back out. (I did also chg. the oil filter as well)? Thanks
Old Dec 29, 2013 | 03:47 PM
master tech's Avatar
master tech
Site Moderator & Tech
If the level shows just above the safe line. You are okay, don't worry. Before you changed the oil, did you remove the filter first. Because the filter will have some oil left in the filter. The factory recommend to remove the filter first and leave it out until you have drain the engine oil. Then install the new filter. And add the oil to the engine.
Old Jan 2, 2014 | 09:01 AM
fielldboss's Avatar
fielldboss
Default thanks
I did remove the oil filter 1st, but I replaced the new filter while the oil was draining out of the pan.
Old Jan 2, 2014 | 09:20 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
if its just above like a 1/8 of the line would not worry about it. dealer did oil change on mine did that too. althought over filling Is not to good as well.
Old Jan 2, 2014 | 11:23 PM
Lscman's Avatar
Lscman
did you possibly check the dipstick before starting the engine for the first time, after the oil change? If so, it will read very high because the filter will be empty. I always fill my oil filters before installing them to avoid momentary oil starvation upon startup.
