[2nd Gen : 91-95]: 94 DodgeCaravan 3Liter engine light
Old Jan 9, 2014 | 07:21 PM
stockups's Avatar
stockups
Default 94 DodgeCaravan 3Liter engine light
Need some Help my engine light is coming on more and more I check the codes and the only code I am getting is code 35 air conditioner clutch can someone give me some advice on what might cause the engine light to come on I have a new O 2 sensor but I do not want to waste money to install it if that's not the problem also I recently had a tune up done
Thanks michael
Old Jan 10, 2014 | 02:56 PM
mike39648's Avatar
mike39648
take off your air filter box and the O2 sensor is right there on the exhaust manifold. Spray some wd40 around it and disconnect the electrical connector. Screw the old one off and screw the new one in. The rest is reverse process. That would probably be your problem because I had the same issue on mine about 10 years ago. I paid $98 for the dodge dealership to do this and all it took the mechanic was 15 minutes to do. I watch how he did it
Old Jan 20, 2014 | 09:22 AM
stockups's Avatar
stockups
Smile you are correct
Thanks Mike I just had the work done I try to do it but i couldn't so i brought it to someone they charge me 60 bucks it took them like you said no more then 15 minutes
