[4th Gen : 01-07]: Tail/Brake Light Issues
I'm stumped.
Passengers side only, when I turn on my lights I have no tail light, but I do have a brake light.
I've replaced the bulb and I've cleaned the connections. It's the same bulb for tail/brake so it doesn't make any sense that it works one way and not the other.
Hints, advice? Thanks in advance.
Check for power and ground at the connector using a multimeter. If both are there swap the light assemblies left to right. If one isn't there chase the open wire from the IPM to the light assembly connection. Model year?
