[5th Gen : 08+]: Headlight stays ON when locking doors
Old Jan 22, 2014 | 03:17 AM
dellsam34's Avatar
dellsam34
Default Headlight stays ON when locking doors
I have noticed an intermettant problem when locking doors with the remote key, the headlights would turm ON and stay that way for about 2 minutes and they turn OFF, It doesn't happen every time, I also find out that opening the door and cycling the headlight switch to ON and OFF the headlights will turn off right away, Any idea how to fix this problem?
Old Jan 22, 2014 | 06:27 AM
2013 Grand_caravan SE_17s's Avatar
Does it only happen in low light conditions?
Old Jan 22, 2014 | 02:55 PM
Cougar41's Avatar
Cougar41
From reading around the net many Chrysler made vehicles have a headlight delay off feature that's adjustable by either you pushing buttons or a dealership using a scanner. Whether it activates or not can depend on how light or dark out it is. Anything in your owners manual about it?
Old Jan 25, 2014 | 03:27 AM
dellsam34's Avatar
dellsam34
I havn't tried it in the day, but at night it doesn't happen all the time, so I know it's an intermettant problem.
Old Jan 25, 2014 | 04:35 PM
Cougar41's Avatar
Cougar41
The powers that be say you own an 08 so you may have a TIPM headed south. It controls headlights and RKE and SRS functions. Check for corrosion or damage on the connections. You could have it reprogrammed but considering the intermittent nature I'd think the previous is more likely.
Old Jan 25, 2014 | 10:55 PM
spudkiss's Avatar
spudkiss
Default re
on my 2010 SE caravan. i use the dome light switch and turn it off somehow keeps the daylight from staying on to long as well.
Old Jan 29, 2014 | 03:20 AM
dellsam34's Avatar
dellsam34
Yeah that's weired, mine does that 1 out of 15, and even if it does the headlights will turn off after one or two minutes so it shouldn't drain the battery, I probably just live with it as the warranty run out and I don't want to deal with those reduculous dealer fees.
