[4th Gen : 01-07]: 2006 caravan 3.3 liter
Problem: Engine has a light knock at all times and when running high RPMs, it bogs down and releases repeatedly (maybe 2 second intervals). This is while sitting and revving the engine with a steady pedal. the knock was noticed about two weeks ago. Lees than one week ago, the check engine light came on and the egr valve was replaced. That is when I noticed the high rpm issue.
I'm sorry to hear about the issue you've experienced. Since the EGR replacement, is the check engine lamp still on? Was the dealer able to experience the symptoms you've described?
The check engine light has not been on since the egr valve replacement. I have not taken it to a dealer at this point, but will be taking it later today. I just don't know how long it is going to be before they get to really looking at it if it is not a simple problem.
sauria,
When bringing the issue to the dealer's attention, it would benefit the diagnosis process if you are able to show the service dept. specifically what is occurring with the van. Perhaps sitting in the vehicle and demonstrating the concern is necessary. Be sure you speak with the Service Manager for additional technical advice.
