[General]: 02 grand caravan
Old Mar 22, 2014 | 06:39 PM
jeremy45's Avatar
jeremy45
Default 02 grand caravan
the front end starts to shake at 40mph and gets worse the faster i go.
i have replace the wheel bearings , lower control arm and ball joints, sometimes the car is fine and other times it shakes like crazy and u can hear some clunking u first take off from a stop and squeaking while driving. i know the stabilizer bar linkiage going upto the shocks are worn could this be the problem?
Old Mar 23, 2014 | 03:32 AM
Cougar41's Avatar
Cougar41
I'm guessing you forgot to say rotating the tires front to back did nothing to help. Mainly shaking/clunking on acceleration? Also guessing you may have an inboard cv joint on it's way out. Stab bar bushings and links may cause squeaking/knocking but little else.
