[4th Gen : 01-07]: 03 caravan tcm
Old Apr 12, 2014 | 04:22 PM
newfieryder's Avatar
newfieryder
Default 03 caravan tcm
Hi All
I have 03 caravan 3.3 it went into limp mode all shifter lights turned orange the the speedo wouldn't work and getting a misfire so I changed the output and input sensors no difference I also changed a few other engine sensors no difference so I had a tcm in good shape off a stratus I think so I said what the hell ill try it the van came out of limp mode the shift lights work as normal my speedo came back I know I need a tcm to match the the van ive got 1 on order now but what I was wondering is can I do damage with the wrong one on the van
Thanks very much
Great place here also
Old Apr 13, 2014 | 01:09 AM
master tech's Avatar
master tech
Site Moderator & Tech
You may get a check engine for a mismatch vin and the speedo may not read correct because you haven't the pinion factor from the tire size that's on the van.
